Update solution after extension of time
Posted 26 mai 2012, 04:59 UTC−4 2 Replies
If I leave my entire model identical, but change the time dependent solver to run to a longer time (same initial time, same time step) and then hit "Update Solution", how can I make COMSOL use the existing solution up to the previous maximum time, and only calculate the times after this? From the "Progress" tab it appears to be calculating the entire solution again.
Thanks for any help,
Andrew
Andrew
2 Replies Last Post 7 oct. 2015, 04:47 UTC−4
