simulate the temperature of an expanding gas in laval nozzle
Posted 1 juin 2012, 09:37 UTC+2 Fluid & Heat, Heat Transfer & Phase Change 2 Replies
hi,
is it possible to simulate the temperature of an expanding gas? I have an ideal gas which flows thourg a laval nozzle and I need to know the temperature when the gas is expanding because then it is possible to have velocities >Mach=1.
But if I use the "convection and conduction" and set the temperature in boundary settings, it contains constant. So I think comsol doesn't solve the temperature because of the expanding gas but only the transfer of the temperature through the gas. So I wonder if it is generally possible to simulate the temperature decay of the expanding gas.
2 Replies Last Post 1 juin 2012, 11:20 UTC+2
