Streamline along a line or plane
I have a 3D model of a system of permanent magnets and am trying to obtain a streamline of magnetic flux density along specific planes in my model.
In the settings for a streamline plot there is an option for positioning the streamline along a plane but the drop down menu provides no options for selecting / defining a specific plane. Is there a way for me to define my streamline for a specific plane?
Thanks for your help!
Ben
2 Replies Last Post 26 juil. 2013, 22:01 UTC+2
Hello Benjamin Rardin
Posted: 1 decade ago 26 juil. 2013, 21:31 UTC+2
Bump.
Any solution? Possibly you could define a work plane, and then under "Streamline Positioning" --> "Positioning" choose "Selected Boundaries", where you can isolate the workplane...
I do not want to re-run my simulaiton to try it at this point. Can anyone test?
-Bryan
Bump. Any solution? Possibly you could define a work plane, and then under "Streamline Positioning" --> "Positioning" choose "Selected Boundaries", where you can isolate the workplane... I do not want to re-run my simulaiton to try it at this point. Can anyone test? -Bryan
Posted: 1 decade ago 26 juil. 2013, 22:01 UTC+2
Ah! I think I have it!
Use a "start point controlled" positioning, and identify a range in a given plane. Then under Expression, you should zero out the out-of-plane component.
Using this way, I was able to isolate current densities superimposed on the two separate planes of my multislice surface plot.
-Bryan
Ah! I think I have it! Use a "start point controlled" positioning, and identify a range in a given plane. Then under Expression, you should zero out the out-of-plane component. Using this way, I was able to isolate current densities superimposed on the two separate planes of my multislice surface plot. -Bryan
