Robert Koslover
        Certified Consultant
                                4 years ago
                                26 juin 2021, 16:35 UTC−4
                                                    Are you saying that your assignment of impedance boundaries on the metallic parts causes the model to not be able to form a union, while having them with PEC conditions instead allows a union to be formed?  And you made no other changes?  If so, that seems like very strange model behavior to me.  If your model (or a similar one that you have) displays this behavior clearly/reproducibly, please post it to the forum so that those reading here can investigate it in more detail.
                            Are you saying that your assignment of impedance boundaries on the metallic parts causes the model to *not* be able to form a union, while having them with PEC conditions instead *allows* a union to be formed?  And you made no other changes?  If so, that seems like very strange model behavior to me.  If your model (or a similar one that you have) displays this behavior clearly/reproducibly, please post it to the forum so that those reading here can investigate it in more detail.
                                4 years ago
                                27 juin 2021, 06:27 UTC−4
                        Updated:
                                4 years ago
                                27 juin 2021, 08:27 UTC−4
                                                    I have the exact same problem
I wanted to simulate the example Frequency Selective Surface, Periodic Split Ring Resonator with impedance boundary condition instead of PEC (ie copper on the metallic parts).
What should i do in terms of physics?
Thank you in advance
                                4 years ago
                                29 juin 2021, 06:06 UTC−4
                                                    So for anyone who is struggling with this type of simulation:
If you want to put thick metal objects instead of pec you have to follow the steps below:
1) in the work plane,draw your flat objects
2) extrude them
3) in the electromagnetic waves,uncklick the domains(thick metal objects arised from extrude) from the simulation
4) the top boundaries of your object are now "exetrnal" boundaries,and you can apply IBC
5) reddit for the win
2) extrude them
