Error occuring during the calculation
Anyone know what this error is and how can I fix the error?
''A problem has occurred with the following feature. - Feature: Time-dependent solver 1 Original Datei /home/nschnell/.comsol/v56/csmphserver71020/solblock2552_7731729166784022528.mphbin cannot be generated.''
Is there any file missing from my program you think?
Best Regards
1 Reply Last Post 6 juil. 2021, 02:29 UTC+2
Posted: 4 years ago 6 juil. 2021, 02:29 UTC+2
Sounds like you are trying to create/write/export a .mphbin-type of file to a particular directory, but that the software either couldn't write to that directory or doesn't have the information to write available. Under what circumstances did/does the error occur? Does/did this same error occur when running all your Comsol models (even including Comsol-supplied sample files?) or is it just this one model? The more you tell the community here, the more likely you will be to get good advice.
