Problems with the solutions of a parametric sweep simulation
Posted 20 juil. 2021, 23:24 UTC+2 Electromagnetics, Heat Transfer, Results & Visualization 0 Replies
Hi, I have problem with the solutions of a parametric sweep simulation, I can not plot the data from Results, I get empty plots. I could operate with the solution when calculations ended, but after opening the saved comsol file again I see Results, but can not operate with calculated values, I get empty tables. The parametric sweep simulation Results files are 2 GB. Anna
Hello Anna Balata
