Calculate & compare two separate simulations on the same geometry
Posted 19 juin 2012, 09:05 UTC−4 Fluid & Heat, Microfluidics, Results & Visualization, Studies & Solvers Version 4.2a 1 Reply
I have done a laminar flow simulation (including the inertial term), and now would like to do the same simulation (identical geometry, meshing, boundary conditions) with the inertial term neglected.
Then I would like to compare the two solutions by creating the difference (DataSets-Join shoud do that) and plot the result as a 3D-Slice.
How do I go about calculationg two seperate solutions in the same Model?
Thank you.
Thank you.
1 Reply Last Post 21 juin 2012, 11:15 UTC−4
