Henrik Sönnerlind
COMSOL Employee
4 years ago
1 sept. 2021, 11:39 UTC+2
To add perform a repetitive task, you can use either a Model Method, a Java Script, or (if you have such a license) Matlab scripting.
This said, adding 10^6 nodes to the model tree will make your model essentially impossible to work with. What is the background story for the 10^6 loads? Is it a distributed load that you try model in this way? If so, it is probably better to work with boundary loads and interpolation functions.
Henrik Sönnerlind
COMSOL
4 years ago
2 sept. 2021, 18:13 UTC+2
Thanks Henrik for your reply. They are individual known point loads. Your idea of interpolating the load is interesting. If I input a table with X, Y, Force (directed in Z) values and create an interpolated load, can I apply that to the model surface?
4 years ago
3 sept. 2021, 00:59 UTC+2
The force components associated with a Boundary Load node can be functions of position, so I assume that an interpolation function can also be used there (haven't done this myself however).
Indeed, in Comsol almost any box that takes a numerical input will also accept functions.
4 years ago
3 sept. 2021, 03:09 UTC+2
Yes that works. One can enter int1(x,y) for a z-direction boundary load. Thanks!
