Simulating movement
I'm trying to simulate the movement of a certain body when it is subjected to wind forces.
Is there any easy way to do this in Comsol.
Thank you
Viddy
2 Replies Last Post 28 juin 2012, 13:03 UTC+2
Posted: 1 decade ago 27 juin 2012, 18:55 UTC+2
there are two ways: either you know the pressure field spatially and temporally (or in frequency content) and you apply this as a boundary pressure load to your Solid (structure physics),
Or you go for a full FSI (fluid-structure interface) physics which is far heavier but gives a coupled interaction: the wind pushes the structure that changes the wind shape etc.
But a more complex model means more time to set it up, to run it, and to validate it, not to say larger computer(s), you might need a cluster depending on your model size
Hi there are two ways: either you know the pressure field spatially and temporally (or in frequency content) and you apply this as a boundary pressure load to your Solid (structure physics), Or you go for a full FSI (fluid-structure interface) physics which is far heavier but gives a coupled interaction: the wind pushes the structure that changes the wind shape etc. But a more complex model means more time to set it up, to run it, and to validate it, not to say larger computer(s), you might need a cluster depending on your model size -- Good luck Ivar
Posted: 1 decade ago 28 juin 2012, 13:03 UTC+2
Thank you, for your advise, its much appreciated.
I'll give it a go.
Thank you, for your advise, its much appreciated. I'll give it a go.
