Acculution ApS
Certified Consultant
4 years ago
4 nov. 2021, 18:41 UTC+1
Hi Natalia,
Do you have some more information on this? Are you trying to compare to an analytical solution, or some solution found in a paper? It is really up to you to apply the boundary conditions that you see fit.
René Christensen, PhD
Acculution ApS
www.acculution.com
info@acculution.com
Hi Natalia,
Jeff Hiller
COMSOL Employee
4 years ago
4 nov. 2021, 19:28 UTC+1
Updated:
4 years ago
4 nov. 2021, 19:51 UTC+1
Natalia,
It's not clear to me that you should be using the acoustic-solid interaction physics interface. From your post, I gather that you're interested in modeling vibrations only in solids. You may want to start by looking at models from the Application Gallery that are conceptually similar to what you want to model as a starting point.
Jeff Hiller
Natalia,
It's not clear to me that you should be using the acoustic-solid interaction physics interface. From your post, I gather that you're interested in modeling vibrations only in solids. You may want to start by looking at models from the [Application Gallery](https://www.comsol.com/models) that are conceptually similar to what you want to model as a starting point.
