Internal error in geometry composition, Comsol 4.2a
Posted 3 juil. 2012, 11:10 UTC−4 1 Reply
I want to make blocks with round edges in 3D. I use standard procedure, I define workplanes, make geometrical objects in 2D, do "extrude", end on the end - INTERSECTION.
When I do these steps in Comsol 4.2a version 4.2.1.110 (older version) everything is OK, but when I do the same in
Comsol 4.2a version 4.2.1.166 (newer version) I receive message:
"Internal error in geometry composition"
Please if someone have a solution for this problem because I need to solve this in newer version because on workstation on which I work is the newer Comsol. I tried to make this module in older version and then to open it in newre version, but then I receive some message about problems with CAD import module.
Thanks in advanced.
Hello Nikola Bralovic
