Change global parameters as the frequency changes
Posted 15 déc. 2021, 06:30 UTC−5 Wave Optics Version 5.5 0 Replies
I have a sellmeiers equation to calculate the refractive index of material and is defined in global parameters (initial lambda = 1550 nm)
Eg: n_Si = 1 + (0.00898 lambda^2/1104lambda^2)
lambda = c_const/frequency
As i am performing the frequency domain (range 19145GHz to 19864GHz), the value of n_Si should be changed. I tried using with variable freq but it shows error. Could you please help me with this?
Hello Ravi Hitesh Patel
