No mesh on domains
Posted 23 déc. 2021, 18:53 UTC+1 6 Replies
Dear All,
I have actually meshed all the domains but when I computed, it showes Warnings in sol1 of study, saying "No mesh on domains 1-18 in the meshing sequence with tag mesh1. This may lead to incorrect results." and at the same time there was an error massage "Failed to find a solution. Singular matrix.
There are 686454 void equations (empty rows in matrix) for the variable comp1.T. at coordinates: (0.0881393,0.0371038,0.2286), (0.0881813,0.0374595,0.21717), (0.0881953,0.037578,0.208026), (0.0817499,0.0359305,0.212598), (0.0854638,0.0384823,0.2286), ...
and similarly for the degrees of freedom (empty columns in matrix). Returned solution is not converged. Not all parameter steps returned. "
I just use heat transfer module.
Thank you so much!
