Question about frequency selective surface
Hello.please I have a problem in comsol. When I simulate the Frequency selective surface with patch metallic i can find the results. But when I simulate the same structure but with patch dielectric i can't find any results. Please if one here have a solution help me please
3 Replies Last Post 2 janv. 2022, 18:22 UTC+1
Posted: 4 years ago 2 janv. 2022, 02:05 UTC+1
Updated: 4 years ago 2 janv. 2022, 02:06 UTC+1
I encourage you to post your model to the forum so that others here can take a detailed look at it. (In fact, you might want to post both the models that you mentioned, so we can all see what you actually changed, when you replaced metal by dielectric. This way, we will be more likely to figure out why one model worked and the other didn't.)
I encourage you to post your model to the forum so that others here can take a detailed look at it. (In fact, you might want to post *both* the models that you mentioned, so we can all see what you actually changed, when you replaced metal by dielectric. This way, we will be more likely to figure out why one model worked and the other didn't.)
Posted: 4 years ago 2 janv. 2022, 06:27 UTC+1
Thanks dear. but where i can post my model of comsol. best regards
>I encourage you to post your model to the forum so that others here can take a detailed look at it. (In fact, you might want to post *both* the models that you mentioned, so we can all see what you actually changed, when you replaced metal by dielectric. This way, we will be more likely to figure out why one model worked and the other didn't.) Thanks dear. but where i can post my model of comsol. best regards
Posted: 4 years ago 2 janv. 2022, 18:22 UTC+1
You can post your .mph file to this forum. You should see a statement that says "Drag here or browse to upload" at the bottom of the Reply box, in this forum. If your file is over 5 MB in size, click on the link that says "Learn how to reduce MPH-file size."
