Edgar J. Kaiser
Certified Consultant
4 years ago
12 janv. 2022, 12:08 UTC+1
Mateusz,
it should be straightforward to implement the analytic function. What is the problem in detail?
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Mateusz,
Cheers
Edgar
4 years ago
31 janv. 2022, 01:41 UTC+1
I have the same problem
4 years ago
31 janv. 2022, 02:34 UTC+1
Posting your (reduced) model will yield the most informed responses.
However- when simulating very abrupt and short transients it is important to choose the time stepping settings carefully.
4 years ago
31 janv. 2022, 15:04 UTC+1
The problem is, I don't know how to enter time-varying data into the comsol
4 years ago
31 janv. 2022, 15:07 UTC+1
Did you find a solution to this problem?
Jeff Hiller
COMSOL Employee
4 years ago
31 janv. 2022, 20:02 UTC+1
Updated:
4 years ago
31 janv. 2022, 20:06 UTC+1
Hello Bouderbala,
The COMSOL GUI is interpreted, so you can type mathematical expressions in the user interface pretty much like you write them on a piece of paper. This has been discussed many times in this Discussion Forum (For instance, here ), and for an extensive discussion of the syntax and available function I will refer you to the documentation, which is accessed through File > Help > Documentation in the software itself. When solving a time dependent problem, "t" is time.
Jeff Hiller
Hello Bouderbala,
The COMSOL GUI is interpreted, so you can type mathematical expressions in the user interface pretty much like you write them on a piece of paper. This has been discussed many times in this Discussion Forum (For instance, [here](https://www.comsol.com/forum/thread/122051/error-while-calling-external-c-function?last=2016-08-26T11:03:59Z) ), and for an extensive discussion of the syntax and available function I will refer you to the documentation, which is accessed through File > Help > Documentation in the software itself. When solving a time dependent problem, "t" is time.
