Fluid- Piezoelectric material
I have been trying to obtain steady state solution for flow patterns in a microchannel when the fluid is excited by the displacement of piezoelectric material. The issue is that I get non-zero displacement on piezo, but zero velocity. What's even more baffling is that I get non-zero acceleration. This does not make any sense to me.
I am unable to attach my model as it gives me a file size error.
Thanks!
Regards
Nitesh
2 Replies Last Post 20 juil. 2012, 10:50 UTC+2
Posted: 1 decade ago 20 juil. 2012, 10:29 UTC+2
remove the solution and the mesh (Edit Clear all solutions, Clear Mesh) and then File Reset history, then save with a new name and upload that, its much smaller ;)
Sorry in V3.5 you should clear the solution only first, as removing the mesh removes the meshing strategy that can be complex, and resetting the history might generate a binary file of your geometry, that you must upload too for others to use the model
Hi remove the solution and the mesh (Edit Clear all solutions, Clear Mesh) and then File Reset history, then save with a new name and upload that, its much smaller ;) Sorry in V3.5 you should clear the solution only first, as removing the mesh removes the meshing strategy that can be complex, and resetting the history might generate a binary file of your geometry, that you must upload too for others to use the model -- Good luck Ivar
Posted: 1 decade ago 20 juil. 2012, 10:50 UTC+2
Thanks for your reply.
Please find attached my model.
Regards
Nitesh
Thanks for your reply. Please find attached my model. Regards Nitesh
