How to simulate the wear in dynamic friction ?
I have read the case of "Disc Brake Pad Wear" in the offical website. It says "By adding a Slip Velocity subnode to the Contact node, you can solve for dynamic friction forces even in a stationary study." But what if I want to simulate a dynamic friction situation, for example, a ball slides across a steel surface and leaves a long worn mark, how can the Comsol acheive this?
1 Reply Last Post 7 mars 2022, 14:19 UTC+1
Posted: 3 years ago 7 mars 2022, 14:19 UTC+1
You just use the ordinary Friction node, combined with Wear. The Slip Velocity is a convenience utility for stationary analysis.
Henrik Sönnerlind
COMSOL
You just use the ordinary *Friction* node, combined with *Wear*. The *Slip Velocity* is a convenience utility for stationary analysis.
