Calculation of Contact Area between two Surfaces
https://cn.comsol.com/forum/thread/206041/deformed-surface-area-calculation
The calculation method given in this link can no longer be used. The hemispherical elastic material deforms after being pressed by the steel plate. Is there a method to calculate the contact area between the elastic material surface and the steel plate?
1 Reply Last Post 8 mars 2022, 09:43 UTC+1
Posted: 3 years ago 8 mars 2022, 09:43 UTC+1
Instead of integrating the expression '1', which would give the whole area of a boundary, you can integrate an expression like 'incontact_p1'. This is a boolean variable which has the value 1 where the contact condition is fulfilled and 0 outside. The suffix 'p1' is the name of the contact pair.
Henrik Sönnerlind
COMSOL
