Topology Optimization: Magnetic Field 3D Coils
I tried to apply topology optimization to magnetic fields in 3D in specific working with coils. I found problems in the study using the combination of Coil Geometry analysis and topology optimization. Do you know some hints that I should consider to simulate topology optimization in 3D for magnetics fields for coils?.
Gracias.
1 Reply Last Post 10 mars 2022, 08:30 UTC+1
Posted: 4 years ago 10 mars 2022, 08:30 UTC+1
Updated: 4 years ago 10 mars 2022, 08:30 UTC+1
This sounds like a problem you might want to reconsider. If the coil is made up of 'islands' as the optimization is running, how will comsol be able to calculate eg currents?
René Christensen, PhD
Acculution ApS
www.acculution.com
info@acculution.com
