Required Elasticity Matrix, Coupling Matrix, Relative Permittivity Values Of Structural Steel
Greetings, I am working on a simulation where I am using Structural steel layer in between two pizeeclectric material layers. However, I require parameters like Elasticity Matrix, coupling matrix and relative permittivity to acquire a solution. Please do help me if there is any solution to this problem.
Thank you
5 Replies Last Post 17 mars 2022, 21:50 UTC+1
Posted: 3 years ago 15 mars 2022, 12:25 UTC+1
Steel is not piezoelectric, so you should use Linear Elastic Material, not a Piezoelectric Material in that domain.
Henrik Sönnerlind
COMSOL
Posted: 3 years ago 16 mars 2022, 05:25 UTC+1
I am using Lead Zirconate Titanate (PZT-5A) as my piezoelectric material while using a layer of structural steel in between both layers of PZT-5A, yet I am being asked for the parameters mentioned above.
>Steel is not piezoelectric, so you should use Linear Elastic Material, not a Piezoelectric Material in that domain. I am using Lead Zirconate Titanate (PZT-5A) as my piezoelectric material while using a layer of structural steel in between both layers of PZT-5A, yet I am being asked for the parameters mentioned above.
Posted: 3 years ago 16 mars 2022, 13:54 UTC+1
The reason you are being asked for those parameters is that the steel domain is included in the selection in the Piezoelectric Material node.
Henrik Sönnerlind
COMSOL
Posted: 3 years ago 17 mars 2022, 17:53 UTC+1
Updated: 3 years ago 17 mars 2022, 17:53 UTC+1
Thank you sir. Would you be able to tell me how do I change the node for that very specific material?
>The reason you are being asked for those parameters is that the steel domain is included in the selection in the Piezoelectric Material node. Thank you sir. Would you be able to tell me how do I change the node for that very specific material?
Posted: 3 years ago 17 mars 2022, 21:50 UTC+1
It is simple: Leave all domains in the default Linear Elastic Node, except the Piezoelectric domain. Check respective application library models.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
It is simple: Leave all domains in the default Linear Elastic Node, except the Piezoelectric domain. Check respective application library models. Cheers Edgar
