parallel computing on cluster
Posted 29 mars 2022, 08:36 UTC+2 Fluid & Heat, Heat Transfer & Phase Change, Computational Fluid Dynamics (CFD) Version 5.6 0 Replies
Hlo, I'm trying to use cluster computing by adding this node in the study. I followed this blog https://www.comsol.com/blogs/how-to-run-on-clusters-from-the-comsol-desktop-environment/ but stuck while I am submitting my job without using any scheduler script. My doubt is how will I define, to which node job will go for computation as in the queue name it mentioned only cluster. Thanks in advance
Hello Garima Varshney
