Degree of Freedom
Hi, I am using 4 quadratic element in 2D square geometry for calculation of temperature. I get 9 values of temperature at each node using function mpheval, but when i use fuction mphmatrix to get K matrix it come 25x25. It says number of degree of freedom is 25.
How it is possible for scalar 2D Heat conduction problem? The K matrix should also be 9x9.
I am unable to find in document regarding degree of freedom. and internal degree of freedom Please help.
Hitesh Kumar Sinha Thank You
3 Replies Last Post 23 mai 2022, 11:36 UTC+2
Posted: 3 years ago 18 mai 2022, 13:01 UTC+2
If you look under Discretization in the Heat Transfer in Solids node, you will see that the shape functions used are Quadratic Lagrange, so there are 25 nodes in the mesh.
If you want to visualize the nodes, add a Mesh plot in any plot group, and select the physics interface in the Node points drop-down menu.
Henrik Sönnerlind
COMSOL
If you look under *Discretization* in the *Heat Transfer in Solids* node, you will see that the shape functions used are *Quadratic Lagrange*, so there are 25 nodes in the mesh. If you want to visualize the nodes, add a *Mesh* plot in any plot group, and select the physics interface in the *Node points* drop-down menu.
Posted: 3 years ago 23 mai 2022, 10:35 UTC+2
Hi Hitesh
mpheval assumes first order elements by default.
If you set 'refine' to 2 then you'll get the second order information - and usually much larger matrices.
Lars Gregersen
Comsol Denmark
Hi Hitesh mpheval assumes first order elements by default. If you set 'refine' to 2 then you'll get the second order information - and usually much larger matrices.
Posted: 3 years ago 23 mai 2022, 11:36 UTC+2
Thank Henrik and Lars. Thank you so much for your reply. I helped me alot, thank once again for your guidence
