Strain reference Temperature
I am using transient themal stress analysis (ts) to solve a 3D problem in Comsol 4.2. My understading is that in order to compute the thermal stresses inside the material geometry, the ts model must require strain refrence temperature as input. The Strain Reference Tempertaure model input parameter under Thermal Linear Elastic 1 node, however is grayed out in 3D model. It is active only for 1D and 2D cases. I could possibly be missing something. Will greatly appreciate if someone could throw some light on to this issue.
With many Thanks,
R.K.
PS: Regardlesss of this input, the COMSOL is able to solve the problem and generate the temerature and stress distributions.
1 Reply Last Post 13 août 2012, 08:31 UTC+2
Posted: 1 decade ago 13 août 2012, 08:31 UTC+2
in my V4.3 its not greyed, apart for Thermal Linear Viscoelastic Material node, for which you need to first "turn on" the Thermal expansion by a tick mark
Could it be that you have several "T" dependent variables from other physics and COMSOl has choosen anothe T as the driving value ??
Hi in my V4.3 its not greyed, apart for Thermal Linear Viscoelastic Material node, for which you need to first "turn on" the Thermal expansion by a tick mark Could it be that you have several "T" dependent variables from other physics and COMSOl has choosen anothe T as the driving value ?? -- Good luck Ivar
