High Mach number flow and heat transfer problem?
Posted 18 juil. 2022, 02:58 UTC−4 Fluid & Heat, Results & Visualization, Physics Interfaces Version 5.6 0 Replies
We use the high Mach number flow(k-epsion) to simulate the heat transfer of the fluid and solid part. If we add no heat source in the model, the results are relatively reasonable, But when we add a boundary heat source inside the model, the temperature changes only occur in the solid part and do not affect the fluid part--there will be a temperature jump in the boundary!! Anyone knows the reason for the problem?
Hello Ge Tsuna
