Importing data from text file to a 3D domain
I am trying to use an external file which contains the temperature data in certain points of the geometry. The data in the file looks like below.
NodeNumber X Location(m) Y Location(m) Z Location(m) Temperature (°C) 1 -0.23 2.62E-02 -0.85 1522.4 2 -0.23 3.50E-02 -0.85 1234.3 3 -0.21844 2.62E-02 -0.85 1522.4 4 -0.21844 3.50E-02 -0.85 1265.3 5 -0.23 2.62E-02 -0.86136 1522.3
I neeed to use this temperature distribution as load in other physics.
Is it possible to import the 3D data (for example temperature or pressure) available in a text file into a 3D geometry ?
If possible, can you please suggest the procedure and share the useful links.
0 Replies Last Post 17 août 2022, 19:42 UTC+2
Hello Pedduri Jayakrishna
