Frequency Sweep Fails to solve around Eigen Frequencies
Posted 29 août 2012, 15:41 UTC−4 1 Reply
I'm simulating a SAW device, using the Piezoelectric module I get eigen frequencies around 100Mhz, but when i sweep up with small steps like 50Hz Step the solver keeps outputting "Failed to find a solution for the initial parameter" only if i sweep around 10KHz or more it solves,
The problem is that i study the effect of heat on the resonance frequencies, the eigen value solver already outputs different frequencies mainly differ around 50Hz in each resonance SAW propagating mode and i want to capture this small variation using a frequency sweep at different temperatures.
thanks
thanks
1 Reply Last Post 30 août 2012, 14:47 UTC−4
