Ignore failed simulations in sweep
Hi there,
is it possible to ignore the failure of single simulated parameter sets within a parameter sweep (Batch Sweep or Parametric Sweep)? I know that for some parameter sets I will run into vrey steep gradients but am not sure for which. I would like to simulate all parameter sets if possible and not have the sweep terminate if one parameter set fails.
Best and thank you in advance for ideas,
David
1 Reply Last Post 15 oct. 2022, 09:51 UTC+2
Posted: 3 years ago 15 oct. 2022, 09:51 UTC+2
After some more searching, I found a reply to a similar question here: https://www.comsol.de/forum/thread/117171/how-to-continue-a-parametric-sweep-in-case-of-a-problem
