Error in modifying diffusion in electrode equation
Posted 7 sept. 2012, 00:42 UTC+2 Battery Design, Studies & Solvers Version 4.0, Version 4.0a, Version 4.1, Version 4.2, Version 4.2a, Version 4.3 2 Replies
I have made this modified model of Li ion battery where I wanted to include stress in the equation of diffusion of Li ions in active particle (for cathode only). Since I am using the standard Li ion battery module of COMSOL so I was unable to change the equation as they are predefined. So, I have separately solved the diffusion equation by making a 2D model. To link it with the concentration of electrode at surface value used by battery module I have inserted the modified value by replacing it using EQUATION VIEW (only the value at surface is changed). But I am getting an error while solving for Time Dependent Case. So, when I tried to solve for Stationary case I got this error:
Undefined value found.
- Detail: Undefined value found in the equation residual vector.
There are 28 degrees of freedom giving NaN/Inf in the vector for the variable mod1.cl
There are 6 degrees of freedom giving NaN/Inf in the vector for the variable mod1.liion.pce1_cs10
There are 6 degrees of freedom giving NaN/Inf in the vector for the variable mod1.liion.pce1_cs8
There are 6 degrees of freedom giving NaN/Inf in the vector for the variable mod1.liion.pce1_cs9
There are 9 degrees of freedom giving NaN/Inf in the vector for the variable mod1.liion.pce2_cs10
There are 9 degrees of freedom giving NaN/Inf in the vector for the variable mod1.liion.pce2_cs8
There are 9 degrees of freedom giving NaN/Inf in the vector for the variable mod1.liion.pce2_cs9
There are 28 degrees of freedom giving NaN/Inf in the vector for the variable mod1.phil
There are 15 degrees of freedom giving NaN/Inf in the vector for the variable mod1.phis
Can someone help me out in this case?
2 Replies Last Post 7 sept. 2012, 15:03 UTC+2
