Different Navier-Stokes equations used in COMSOL
Posted 3 oct. 2012, 10:49 UTC−4 3 Replies
I was using the incompressible navier stokes and found that the governing equation (first picture) applied by COMSOL is a little different from the normal navier stokes equation (second picture), the term for shear stress. When I using COMSOL to simulate the heat transfer through a rectangular enclosure filled by air, it seems that COMSOL's computation result is higher in terms of heat flux. However, it can be adjusted by applying Isotropic Diffusion. I have the following questions?
1. Is this situation caused by the different governing equation?
2.how to use the stabilization techniques? Changing streamline diffusion and crosswind diffusion can only affect the simulation slightly, while isotropic diffusion affect the simulation greatly, so which method I should employ?
Any help?
Thanks in advance.
Any help?
Thanks in advance.
3 Replies Last Post 3 oct. 2012, 12:01 UTC−4
