whats wrong with comsol / my understandig of a differential equation? - thermal conductance
Posted 8 oct. 2012, 16:30 UTC+2 Heat Transfer & Phase Change Version 4.2a 6 Replies
a simple system:
2d
a very small region (we call it region 1), which is defined to be a heat-source, and a neighboring large region (we call it region 2), that shares a boundary with the source. everything is isolated except for one boundary which is a heat-sink. The initial temperature is constant all over the system.
If this system is simulated over time comsol produces smth that is, in my opinion, rather unphysical. ->
Intuitively, i'd say that initially the temperature supposed to be the initial-temperature and depending on the parameters the heat diffuses through the respective materials.
What comsol gives is for some reason already at the beginning a finite temperature that is HIGHER than the initial one, hence for some reason there is a (unphysical) Temperature-JUMP right at the start.
I'm interested in the heat up mechanism so I would like to get rid of this jump since it's unexplainable to me and my colleges!
It's not a matter of the scale. For instance already after e-9 seconds this jump is shown.
And it has also nothing to do with the 'thin thermal resistive layer' that can be defined between the two regions, which i've also checked.
So what the heck is comsol actually doing?
I simply want to get T=T_initial for t=0 as it is defined !!?
2d
6 Replies Last Post 10 oct. 2012, 15:17 UTC+2
