13 oct. 2012, 18:22 UTC+2
often you get clues of what is wrong by first running for the initial conditions (possible as specific commands in 4.3a (&3.5a), from 4.0 to 4.3 you need to run the solver sub-node: dependent variables
15 oct. 2012, 11:01 UTC+2
thanks a lot, was helpful to know that ;-)
Another "problem" I have just realized about...
I have some variables that depends on a lot of things, and all of these are dependent on the time. I am using PDE and time dependent solver, so I see the evolution of my variables along time. That works fine.
I have a very interesting plot that I use to "debug", I mean, to say if everything seems to go right. This plot would be perfect if I could show it for a concrete instant 't'.
Do you have any idea about how I could do that?
(explaining myself a bit better: I run the study from 0 to 1 sec, in steps of 0.001). I would like to see the value of all my variables for t=0.57s, for instance).
The plot is well done, because if I disable the PDE, I see that it works fine for the initial parameters and variables values
Thanks a lot!!
Thanks a lot!!
15 oct. 2012, 11:14 UTC+2
once you have run a simulation you can see the results at any of the intermediated stored solutions (time or spatial all depends onyour model), or you can define a Data-Set extrapolating to the spatial or time desired value, when you have not stored the exact value, but twopositions around the point of interest
15 oct. 2012, 11:22 UTC+2
Ey, thanks a lot for the incredibly quick reply!
Yeah, I am sure there should be a way to do it, since the data is calculated and stored.
I might by skipping something, but my question was how to plot those results at a certain time? Because I know how to plot a variable vs. time, vs. and expression, etc. But I do not know how to make a plot like:
y vs. x at t=0.57s
Sorry if I misunderstand something in your reply, but I still do not know how to do it.
Thanks a lot in advance!
y vs. x at t=0.57s
15 oct. 2012, 12:33 UTC+2
I then propose that you study the doc around Data Set and how to create a derived database structure and calculate on thet
15 oct. 2012, 12:39 UTC+2
Hi, Adrián and Ivar,
As Ivar says, you can select the particular time in the GUI. When you have chosen a time dependent study, at the settings for "Plot", there you can select a particular time (in the "Data"/"Time" list). Nevertheless, you can still select some solution at a particular time through the "at(time, expression)" operator. For instance:
at(5, solid.mises)
gives the von Misses stress at t = 5 s.
Bye,
Jesus.
at(5, solid.mises)
Bye,
Jesus.
15 oct. 2012, 13:12 UTC+2
argggg, now I feel very stupid, I already did that in the past with deformations in 3D.
:P
Excuses for the extra question ;)
Thanks a lot!!!
:P
Thanks a lot!!!
