How Can I Change The Position Of A Imported Model In Comsol?
Hi, How can i change the position of a imported model? I have to modify a file with 4 imported parts in it but I have to space them more from each other. I cannot find any way to move anyone of them.
1 Reply Last Post 29 mars 2023, 13:12 UTC−4
Eric Favre COMSOL Employee
Posted: 3 years ago 29 mars 2023, 13:12 UTC−4
Updated: 3 years ago 29 mars 2023, 13:13 UTC−4
Hi Eve, what about right click on the geometry node, Transform > Move, select the object(s) you want to move and where and that's about it?
More generally, if you are new to COMSOL, the "Learning Center" may be interesting to have a look at : see https://www.comsol.fr/learning-center
good luck,
Eric
Eric Favre
COMSOL France
Hi Eve, what about right click on the geometry node, Transform > Move, select the object(s) you want to move and where and that's about it? More generally, if you are new to COMSOL, the "Learning Center" may be interesting to have a look at : see https://www.comsol.fr/learning-center good luck, Eric
