Jeff Hiller
COMSOL Employee
3 years ago
13 avr. 2023, 14:40 UTC−4
Hello Nived,
Is there a particular reason for exporting the data from one model file only to import it into another, rather than performing the entire analysis in a single model file? It is the easier way to go, when possible.
Jeff Hiller
Hello Nived,
3 years ago
13 avr. 2023, 17:07 UTC−4
Hi Jeff,
Thank you for your reply.
I am currently working on a stationary study of the mfnc module in COMSOL. My goal is to insert different material properties, specifically different BH curves to different nodes, in a single domain. These different material properties are a result of a previous model of the same geometry and mesh. My idea is to extract the nodal data of the particular variable representing the BH curve and re-insert this into my materials. As the BH curve is different at different locations, each node would represent a different BH curve. Ultimately, I need a material which has different BH curves at different locations.
However, I am uncertain if this is possible to achieve in COMSOL. Can provide guidance on how to implement this? I appreciate any input or suggestions on this topic.
Best Regards,
Nived
Hi Jeff,
Best Regards,
Nived
