Modelling involving multiple contacts
I am modelling compaction of a cylindrical hollow drum. In geometry, I have created drum, rigid base and indenter(indenter and base are discs). There is contact between drum bottom and rigid base which is fixed and indenter and top surface of drum. I have prescribed displacement to the indenter and material of drum is taken as plastic(hardening).
I have applied displacement to indenter as a ramped fucntion. While solving, i have applied a parametric sweep in study(stationary solver), but i am getting convergence up to certain point after which solution does not converge. Please suggest how i can resolve this problem.
Thank you, Mayuresh.
2 Replies Last Post 20 avr. 2023, 19:15 UTC+2
Posted: 2 years ago 19 avr. 2023, 15:53 UTC+2
First thing to change is to use an auxilliary sweep in the stationary study step settings, rather than a parametric sweep... without a model file to examine, difficult to suggest more.
I assume you have defined your contact pairs and contact physics nodes?
There are a number of tutorials and application library examples which demonstrate the use of contact within a simulation. I would suggest you start there...
There is also a support article which gives good general advice about setting up contact pairs.
First thing to change is to use an auxilliary sweep in the stationary study step settings, rather than a parametric sweep... without a model file to examine, difficult to suggest more. I assume you have defined your contact pairs and contact physics nodes? There are a number of tutorials and application library examples which demonstrate the use of contact within a simulation. I would suggest you start there... There is also a support article which gives good general advice about setting up contact pairs.
Posted: 2 years ago 20 avr. 2023, 19:15 UTC+2
Thak you very much..!!
>First thing to change is to use an auxilliary sweep in the stationary study step settings, rather than a parametric sweep... without a model file to examine, difficult to suggest more. > >I assume you have defined your contact pairs and contact physics nodes? > >There are a number of tutorials and application library examples which demonstrate the use of contact within a simulation. I would suggest you start there... > >There is also a support article which gives good general advice about setting up contact pairs. Thak you very much..!!
