Setting a maximum limit to a variable
I am creating a user-defined variable for calculating pumping power, which will be a function of pressure difference and flow rate. I will use the pressure difference calculated by COMSOL as the input for the function. However, I want to set a maximum limit for the pumping power value, so that it does not exceed a certain threshold. Is there a built-in function in COMSOL that can help me achieve this?
2 Replies Last Post 23 mai 2023, 08:51 UTC−4
Posted: 3 years ago 10 mai 2023, 13:42 UTC−4
Updated: 3 years ago 10 mai 2023, 13:47 UTC−4
Hello Shaik,
You could accomplish this by using an expression involving booleans to define your pumping power function, something like
which equals f(p) when f(p) is less than 5 and saturates at 5 when f(p) is greater than 5.
Jeff Hiller
Hello Shaik, You could accomplish this by using an expression involving booleans to define your pumping power function, something like ( f(p) < 5 ) * f(p) + ( f(p) > 5 ) * 5 which equals f(p) when f(p) is less than 5 and saturates at 5 when f(p) is greater than 5. Best, Jeff
Posted: 2 years ago 23 mai 2023, 08:51 UTC−4
Thank you for your valuable explanation.
