20 oct. 2012, 20:47 UTC+2
the COMSOl geometric palette lets you draw a polyline easil, by handy, you can then edit the coordinates to make them better suit your need
21 oct. 2012, 10:04 UTC+2
dear Ivar,
Thank you for the quick reply, but I don't want to draw a triangle but a triangular prism. With polygon it is possible to draw a triangle.
Thanks again
Abramo
dear Ivar,
Thanks again
Abramo
[QUOTE]
[/QUOTE]
21 oct. 2012, 10:28 UTC+2
still I do not catch what you are missing ;) extrusion of a closed polygone (wors case combine it) is possible but ok paralle to the surface, if you need to cut it oblique, you need to create a 2nd workplane, perpendicular and make a secont extruded prism and take the difference, still rather easily done ...
21 oct. 2012, 12:17 UTC+2
dear Ivar,
now I got it, Thank you!
Good luck!
Abramo
dear Ivar,
Good luck!
Abramo
[QUOTE]
[/QUOTE]
