Ac current and dc current at the same time
Hello everybody!
I'm using the AC/DC Module, and I need to apply a DC current and an AC current at the same time in the model (3D). I've thought about it and I've found some options:
1. Time dependent model (transient analysis)
2. Multiphysics model (static / time harmonic analysis)
Which way should be the best one? Any other ideas are welcome.
Thanks in advance,
Lidia.
6 Replies Last Post 29 sept. 2011, 04:18 UTC+2
Posted: 2 decades ago 16 févr. 2010, 07:56 UTC+1
Interesting question you have there !
a) transient certainly will do, but if you want to do a frequency sweep you will solve forever, or close to
b) in modal or harmonic you will not see any DC by default, so you must add some formulas in the eqautions to get the DC component (from my understanding).
For me, this question is sufficiently generic and of generla importance that it could be sent to "support" and is worth an example in the model exchange (or even better in next version DOC ;)
Hi Interesting question you have there ! a) transient certainly will do, but if you want to do a frequency sweep you will solve forever, or close to b) in modal or harmonic you will not see any DC by default, so you must add some formulas in the eqautions to get the DC component (from my understanding). For me, this question is sufficiently generic and of generla importance that it could be sent to "support" and is worth an example in the model exchange (or even better in next version DOC ;) Good luck Ivar
Posted: 2 decades ago 23 mars 2010, 01:40 UTC+1
Hi Lidia,
I am having the same problem, and am just very interesting in knowing whether you have been making any progress on this issue?
Johan
Hi Lidia, I am having the same problem, and am just very interesting in knowing whether you have been making any progress on this issue? Thanks, Johan
Posted: 2 decades ago 23 mars 2010, 10:25 UTC+1
Hi Johan,
I'm afraid I'm still at the same point. I've had some advice from technical support, and though they were right on some points (thanks, Linus), it does not work :-(
I'm still trying.
Lidia.
Hi Johan, I'm afraid I'm still at the same point. I've had some advice from technical support, and though they were right on some points (thanks, Linus), it does not work :-( I'm still trying. Regards, Lidia.
Posted: 2 decades ago 23 mars 2010, 10:38 UTC+1
my 2cts on the question
IF the model is linear the best approach will be, in my opinion, to compute the steady state solution and the harmonyc solution separately and add them afterward [ superposition principle is your friend here] [ scripting or post processing depending upon your need]. This is relatively simple
If the model is non linear, I am afraid that the only way to go is to do a transient calculation.
Indeed there are some non linear physical coupling [ often related to material saturation] that CANNOT be grasped accurately otherwis.
Outside and independantly of of Comsol, this problem, along with the solution I am proposing is well known of people that are doing em simulation.
jf
my 2cts on the question IF the model is linear the best approach will be, in my opinion, to compute the steady state solution and the harmonyc solution separately and add them afterward [ superposition principle is your friend here] [ scripting or post processing depending upon your need]. This is relatively simple If the model is non linear, I am afraid that the only way to go is to do a transient calculation. Indeed there are some non linear physical coupling [ often related to material saturation] that CANNOT be grasped accurately otherwis. Outside and independantly of of Comsol, this problem, along with the solution I am proposing is well known of people that are doing em simulation. jf
Posted: 1 decade ago 14 juil. 2011, 20:30 UTC+2
Dear Jean-Francois Leon
I have a problem to add AC current source in COMSOL,I am trying to study the heating problem resulted by electric current for some conductors. I choose heat transfer and electric current as my physics, and for electric current, I create a terminal,the problem is when I set the terminal as 'current' and type a sin function as value, it stoped during my simulation, when I change the terminal to 'voltage' and type the sin function it works right and get the result. And for DC current, it also work right. So how can I apply an AC current to my condutor. Thank you very much!
Yang
Dear Jean-Francois Leon I have a problem to add AC current source in COMSOL,I am trying to study the heating problem resulted by electric current for some conductors. I choose heat transfer and electric current as my physics, and for electric current, I create a terminal,the problem is when I set the terminal as 'current' and type a sin function as value, it stoped during my simulation, when I change the terminal to 'voltage' and type the sin function it works right and get the result. And for DC current, it also work right. So how can I apply an AC current to my condutor. Thank you very much! -- Yang
Posted: 1 decade ago 29 sept. 2011, 04:18 UTC+2
I want to get 20,000 [A] Ac through a copper wire and apply a voltage 1500 [V] how I can do that
Yang
[QUOTE] I want to get 20,000 [A] Ac through a copper wire and apply a voltage 1500 [V] how I can do that -- Yang [/QUOTE]
