Multi-Step Studies
Hello, I'm attempting to run a multi step time dependent study where the second step picks up at the end of the first step. So far, my attempts have failed. Are there any tutorials or examples available to follow?
Thanks.
1 Reply Last Post 2 sept. 2023, 03:54 UTC+2
Posted: 2 years ago 2 sept. 2023, 03:54 UTC+2
Updated: 2 years ago 2 sept. 2023, 03:50 UTC+2
Don't have an example readily available to send you. However, if you post your problem, I can try to show you what you need to do to correct the issue.
James D. Freels, Ph.D., P.E.
