How to draw a parabolic shaped solid?
Hi there,
I am trying to draw a parabolic shaped solid to present an AFM tip. I can draw a parabolic curve in 2D using the paramatric curve function. Then I can do revolve of the prabolic curve. Finally I get a parabolic shell structure insdead of a parabolic solid?
Can you tell me how to get a parabolic solid? Thank you very much!
1 Reply Last Post 14 nov. 2012, 20:42 UTC+1
Posted: 1 decade ago 14 nov. 2012, 20:42 UTC+1
check the convert to solid function of the geoemtry, it should work ;)
Hi check the convert to solid function of the geoemtry, it should work ;) -- Good luck Ivar
