moving mesh - laminar flow+phase set
Posted 10 oct. 2023, 04:29 UTC−4 Mesh, Modeling Workflow, Physics Interfaces Version 6.0 0 Replies
Hi, I’m using the multiphase flow with laminar flow and phase set models for simulating the process of filing a mould and then wiping the excess of fluid with a moving wipe (or blade), as show in the pdf file I use the moving mesh interface and added the automatic remeshing to the solver. Everything works until the time in which the blade “touches” the boundary of the semi-circle I used to define the initial shape of the fluid. If someone could give me some help on how to define the simulation so it does not crash, it would be great. Thank you.
Hello Fabricio Coelho
