geometry
How to extrude a semi-ellipse without an partition in the centre. Anybody help me.
1 Reply Last Post 27 nov. 2012, 11:24 UTC+1
Posted: 1 decade ago 27 nov. 2012, 11:24 UTC+1
In COMSOL your Bezier curves can be set as lines or surfaces (then they are closed surfaces) Is that what you are looking for ?
Select open or closed curve
Hi In COMSOL your Bezier curves can be set as lines or surfaces (then they are closed surfaces) Is that what you are looking for ? Select open or closed curve -- Good luck Ivar
