2D Power Density
Posted 30 nov. 2012, 12:49 UTC−5 Fluid & Heat, Heat Transfer & Phase Change, Computational Fluid Dynamics (CFD) Version 4.3 3 Replies
Good Afternoon,
I am having some trouble calculating what my power density should be in my 2-D model. I am modeling a cross sectional cut of a heated aluminum plate in air. In my experimental runs, the plate has a power of approximately 60 Watts. If I did a 3-D model, the power density would just be 60W divided by the total volume of the plate. But What should I input in a 2-D model. How should this be scaled. I have looked at the previous posts describing this but still am having trouble visualizing it. The total volume of the aluminum plate is 8.8 in^3.
In my current 2D model, I just input 60W/8.8in^3. The simulated model and experimental results are off in temperature (almost by a factor of 2).
Any suggestions would be great.
Lucas
Lucas
3 Replies Last Post 5 déc. 2012, 01:42 UTC−5
