axial compression of an o ring
I'm trying to simulate the axial compression of an o ring between two plates. I'm approaching this problem by taking a 2d section of the o ring.
I'm using the hyperelastic material model for the o ring and using the Mooney-Rivlin model to describe the material. I put the contact between the plates and the o ring, used a auxiliar sweep to simulate the displacement of the upper plate which compresses the o ring.
When the plates starts to come down and hits the o ring, the o ring dissapers and the plate continues to go down. Therefore i don't see any compression of the o ring. I don't even get an error.
Does anyone know where the problem could lie?
Best regards
0 Replies Last Post 22 janv. 2024, 10:09 UTC−6
Hello Yifei Fu
