What coordinates does model.result().numerical().getCoodinates() return?
Posted 15 févr. 2024, 08:35 UTC−5 Interfacing, General, API 0 Replies
I use the COMSOL API to evaluate some expression. For this, I use a dataset that I have successfully computed in COMSOL (Solution 16, Tag: dset5). It is uploaded below.
My syntax is:
extract_w = model.result().numerical().create("disp_field", "Eval") extract_w.set("data", "dset5") # data set used for evaluation extract_w.set("unit", "um") # set units for evaluation
extract_w.set("expr", ["w", "dtang(w, x)"]) # set expression for evaluation
n_data_points = extract_w.getNData() # number of data points in data set node_point_coordinates = extract_w.getCoordinates() # what does this return??
My question is: What coordinates does the method getCoordinates() return? I checked and it's not the mesh coordinates. How are these coordinates selected?
Hello Leo Kon
