time dependent analysis divergence problem
Posted 3 avr. 2024, 03:59 UTC−5 Fluid & Heat, Studies & Solvers Version 5.4 0 Replies
hello.
I am using COMSOL to perform a time dependent analysis and I am facing a situation where the resulting values over time do not converge (smooth continuous values).
The analysis is to calculate the temperature through Joule heating in a simple structure and I need to get a continuous and smooth value with respect to time. Even with a very small time interval, a few microseconds, the calculation shows a discontinuous change in slope at certain points as follows.
Is there any way to prevent this from happening with the time dependent solver option?
Thanks.
you may check the graph image from : ,,,
https://drive.google.com/file/d/1-1vwWjPE7z24-BxKagzqldwba9j11e3r/view?usp=sharing
https://drive.google.com/file/d/1IhpdtN4fqCT-1m8jhsnLi8Z9ysAX_iRD/view?usp=sharing
Hello Wonbin Song
