Electromagnetic Force Distribution
I am working on an E-I electromagnet. I want to connect the forces generated by the electromagnet to a force distribution on a Solid Mechanics module to calculate the stresses on the I beam. How do I get this force distribution? I seem to only be able to get the total force generated by the electromagnet.
1 Reply Last Post 19 avr. 2024, 01:46 UTC−5
Posted: 2 years ago 19 avr. 2024, 01:46 UTC−5
Joseph,
you can simply use the magnetomechanical multiphysics coupling. Check the example 'plate_deflected_by_magnet' in the application library. Of course you must use mf physics in case you want an electromagnetic coil in your model.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Joseph, you can simply use the magnetomechanical multiphysics coupling. Check the example 'plate_deflected_by_magnet' in the application library. Of course you must use mf physics in case you want an electromagnetic coil in your model. Cheers Edgar
