save the mesh points into a text file
How can I save the mesh points into a text file or some similar?
Thanks!
2 Replies Last Post 24 janv. 2013, 00:59 UTC+1
Posted: 1 decade ago 22 janv. 2013, 18:40 UTC+1
I believe if you do Export-Data; Point to evaluate: from data set; Expression: x, y, and z; then you should get the file with the mesh coordinates.
Posted: 1 decade ago 24 janv. 2013, 00:59 UTC+1
Thanks, it works!
There is another option under Export: Mesh. It saves a lot of information besides the mesh coordinates like the elements, but the coordinates are there.
Thanks again.
Thanks, it works! There is another option under Export: Mesh. It saves a lot of information besides the mesh coordinates like the elements, but the coordinates are there. Thanks again.
