Non - Isothermal Flow (nitf)
Posted 28 janv. 2013, 04:13 UTC−5 Fluid & Heat, Heat Transfer & Phase Change, Computational Fluid Dynamics (CFD), Geometry, Modeling Tools & Definitions, Parameters, Variables, & Functions Version 4.3a 1 Reply
                                                    Sir,
I have assigned materials to the domain elements that are required. And, in the step of inspecting the physics part after assigning materials, it is again asking for domain selection. What does that mean?
So for Non-Isothermal Fluid flow (nitf), is it okay of I select the fluid (ie.. water in my case) or should I select solids also. as heat transfer takes place from solid to fluid and viceversa.
1 Reply Last Post 28 janv. 2013, 06:51 UTC−5
