How to model laser induced convective flows using COMSOL?
Posted 30 sept. 2024, 09:26 UTC−5 Fluid & Heat, Heat Transfer, Modeling Workflow Version 6.2 0 Replies
I want to create a model where a laser beam is used to heat up a thin layer (5nm) of gold. It would be required to consider interactions of the laser with both fluid and solid materials as the solid object with the gold layer is submerged in a small micro well. Please refer to the attached document to get an idea about the model.
At this point I believe using "Radiative Beam in Absorbing Media" in COMSOL 6.2 is a good option. Any suggestions would be appreciated.
Hello Menaka Konara
