Solver error only at lower frequencies
Posted 1 oct. 2024, 10:11 UTC−5 Electromagnetics, Studies & Solvers 1 Reply
I am looking at a magnetic fields study in which I want to produce some eddy currents in a copper plate above an alternating magnetic dipole.
I have attached the .mph file
When I run a frequency domain study at 10,000 Hz everything seems to solve fine. When I reduce the frequency to say 100 Hz or 1000 Hz and press the Compute button, I get the following error:
- Feature Stationary Solver 1 (sol1/s1) Failed to find a solution. Matrix has zero on diagonal. Returned solution is not converged. Bot all parameter steps returned.
Can anyone see what the cause is? Thankyou in advance for any input.
